Nothing in the head that hasn't passed thru your body
tcbro
Jun 3, 2004
375
Hunter 33.5 Middle River, MD
I posted this on another thread earlier and decided I shouldn't hijack that thread. I have heard several boat owners say that they enforce this rule on their boats. My question to them is "what do you do with the used TP?". A friend has this rule on his boat and they put the soiled TP in a waste basket. I find this practice a bit repulsive. People on this site are constantly complaining about odors permeating the sanitary hoses, what about a waste basket full of cr*ppy TP stewing in the summer heat? We just use cheap (read thin) TP from the store and it works fine. We even build a "TP nest" in the bottom of the bowl. It helps everything slide down and reduces "skid marks". What is the policy on your boat? If you have this rule, how do you dispose of the soiled TP? Does the RV/Marine TP designed for holding tanks work for you? Sorry if I offended, I'm just curious,
Dec 3, 2003
2,101
Actually, the BVI Charter Fleets...
...now ask you to save "wet" TP in a plastic bag to deposit in the trash, eventually. I was last there in 2006. It seems that the overboard discharge is usually eaten by reef fish, EXCEPT for the paper. Thus, the wholesome properties of paper (?) are not eaten and accumulate on the reefs after sinking and make the reefs less appealing to divers. HOLD ALL TRASH ON STATION until you can take it ashore!
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
I've used this procedure for years on my boat. It has never been a 'smelly' problem. I keep a plastic bag inside a small waste bucket and tie it off after each use. At the end of the day it is removed with all the other trash from on-board. Smelly hoses come from a completely different source and this too can be dealt with. I replaced all my hoses with rigid PVC pipe which does not give off any odor. Alternatively you can make the last flush at days end with fresh water and a small amount of vinegar.
Nov 12, 2006
256
Catalina 36 Bainbridge Island
The Head
What is the problem with TP in the head? Do you not put TP in your toilets at home?
Jun 3, 2004
730
Catalina 250 Wing Keel Eugene, OR
We put TP in the head
We always pumpout, never discharge in the water. I would think that people who pumpout would have no reason to bag the TP seperately.
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
We've used the thin single-ply TP and find it not to be an issue . . .
as long as there aren't large quantities of it. I understand your desire to avoid soiling the bowl, just don't use too much. Single ply breaks down pretty quickly so there is no harm. With that said, we also use babywipes that get bagged if there is a need for cleaning beyond what a "reasonable" amount of TP can provide.
Bob V
Mar 13, 2008
235
Catalina 42mkII Lagoon Point
zip-lock bags
For anything that has not passed through the body. Seal carefully and dispose of in flip top can with plastic bag liner. No odors.
Dec 9, 2006
694
Oday 22 Hickory, NC
If your TP ...
...after soaking in a glass of water overnight has pretty much dissolved...it will do the same thing in the tank. I was amazed the first time I went camping in our travel trailer, after several days of using the head I had to dump the black water tank. (We use a chemical similar to Oderless (Spelling) that Peggie recommends.) I expected to see all sorts of paper and shall we say, 'solids', however it was just like water for the most part. I was amazed at how the chemical broke it down! So back to the paper...put a couple of sheets of your favorite in a galss of water overnight and check it. If it dissolves, you can use it in your heard with no problems. Jack
Feb 17, 2006
5,274
Even better, if you are really anal about this...
(sorry for the pun) Collect some sea water and do the same test. See how the TP breaks down in the environment it will be used. (in my case, I pump in raw seawater and it goes to my holding tank) I can understand the concerns if the paper in use is synthetic in nature. However, if it is truly a paper product, and that is made from wood, wouldn't it have the characteristics of being biodegradable?
Dec 2, 1997
9,011
- - LIttle Rock
Not a bad rule for landlubber guests...'cuz
Landlubbers seem unable to grasp that there's a difference between the quick-dissolve TP provided and the wet wipe or facial tissue they brought with 'em. But there's NO reason for YOU or any crew experienced in using marine toilets to avoid flushing TP, as long as it's the quick-dissolve stuff. In fact, it dissolves so quickly that even a clog from a major "overload" will dissolve on its own if you wait an hour. If it doesn't, somebody flushed something they shouldn't have. Besides, "only if you've eaten it first" isn't 100% bullet-proof either. I've seen manual toilet pumps and y-valves jammed by watermelon seeds...had a customer once whose grandsons couldn't figure out what to do with their bubble gum, so they swallowed it, jamming up the vacuum pump in a VacuFlush system...and a host of other problems caused by previously INgested, but unDIgested, edibles. Btw, Jack...it wasn't the chemical that dissolved the solids and TP, it dissolved because it was in water. It's pretty easy to see how quickly quick-dissolve TP also dissolves in water. Solid waste is 75% water to begin with, is broken up during flushing, and also dissolves fairly quickly in water. Odor prevention/elimination is the only reason to use a tank product.
Dec 9, 2006
694
Oday 22 Hickory, NC
Thanks Peggie...
...I stand corrected. And very appreciative of all of your advice and work on this and other boards. Jack
Feb 6, 1998
11,759
Been using Scott...
Been using Scott singly ply, in the individually wax paper wrapped rolls, for years and years and NEVER ONCE had an issue. If it's safe for septic tanks it's probably safe for your boat. We have lots of guests and lots of inexperienced flushers yet the Scott has worked fine. You don't need to mortgage your house to buy the "marine grade" toilet paper besides the wax paper packaging on the Scott keeps the roll dry on board.. Jeez I really feel bad for those of you stuffing your butt wipes into zip lock bags.... There's just no need!
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
In most of Mexico their minimal soil pipe sizes plug up whenever
they put toilet paper in the toilet so they don't do it. They always put the dirty paper in waste baskets (with disposable plastic trash bags in them). Whenever a toilet backs they automatically think that some unknowing gringo has just used the toilet and run off, leaving them to deal with the plugged toilet. When you've been there awhile you don't think twice about putting paper in a basket, no matter how foul it may seem. On my boat we normally put it in the toilet. Joe S
7,690
Alden 50 Sarasota, Florida
toilet problems
Surprised no one brought this up already - if toilet paper causes problems in your head, you might want to consider replacing it with one that does what it's supposed to do. It seems only reasonable the captain should make the rules, not the toilet.
Ross
Jun 15, 2004
14,693
This problem may also reflect the quality of the fixture.
We have a Raritan 2 and it cheerfully accepts any brand paper I feed it. 8 Years and never a clog.
Ross
Jun 15, 2004
14,693
I have an Edson 30 diaphragm pump.
I have been told that as a test, people have pumped a Tee shirt through one with no clog. So fixtures can be made that don't have to be treated like a fine watch.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
While we use quick dissolve paper
in our manual head, whenever we have guests who are non-boat owners we invoke the rule about not putting anything in the head they haven't eaten first. On more than a few occasions we (I mean me, the plumber) learned the hard way that some folks just use gobs and gobs of paper without any thought to the peculiarities -- and limitations -- of a manual marine head and holding tank. We've found that a small closable plastic pail with a plastic liner works well in keeping the head free of paper clogs and we have never noted any smells from the pail -- which is always emptied at the next marina stop. We've also found that pumping out the holding tank after every trip/use, to include a fresh water rinse with a little liquid soap now and then, really prevents odors nicely.
May 23, 2004
3,319
I couln't imagine sailing around with a bucket full of
used toilet paper. If we had to do that my wife would be so disgusted she would never go on the boat. It is WELL worth the money to buy marine or RV toilet paper and flush it instead of carrying around a can full of used TP. ALso, knowing Murphy's Law as we all do, what do you think is going to happen with that can when it is near full....Eventually it will be a crappy disaster. I have to throw this out since we are "Heading" this way. My toilet was near re-build time and I took Peggy's advice and replaced it with a Raritan PHII. It is nice to know that the toilet will work property everytime you use it. It was well worth the money! Thanks Peggie!
