Bill,
The time required for the drop in oil pressure to be surpassed by the spring has several variables. Most noteibly temperature. If you run the engine for a long time, the alarm should come on sooner.I always listen for the alarm on shutdown as a way of confirming the alarm works. Do you get the light every time? even with out the audible alarm?It can matter, if the audible alarm is failing (light/no audible) then you could miss an oil pressure failure alarm.Pat McCartinInland Marine DieselBuford, GAimd_ga@hotmail.com
