G
Gordon Myers
The Air Conditioners & Ref./Freezer on our h450 use a condensing system using sea water. The sea water enters through a seacock, then strainer, pump, the unit & then back out through another seacock. Normal maintenance includes check & cleaning the strainer. At this time of the Summer, strainers can get real dirty real fast (almost clogged in a short period of time) due to all of the growth taking place in the water of the Chesapeake Bay.To clean the strainer is real easy, but and here are the questions) ...............1. Is anyone concerned about the dirt / growth in the plumbing lines & units?2. How do or would you clean the stuff out of these lines & units?3. Are there any additives of solutions that should be run through the lines & units and if so how often used?Peggie, not a "head" question, but perhaps you might be able to respond.Thanks to all in advance.Gordon (s/y Utopia III)
