Northern Lights Generator
Dec 10, 2012
15
Hunter 410 Rochester, NY
Have a Northern Lights Generator on our Hunter 410. When i start it up and run it it no longer seems to be powering up the AC system. Not sure what i am missing, worked fine early this year and in previous years. My first thought is maybe a bad fuse at the panel but not sure if im skipping some switch or fuse somewhere else ??
Nov 13, 2013
723
Catalina 34 Tacoma
Check the manual. Maybe there's a reset button. Check all your wires and connections for continuity.
Oct 26, 2010
2,124
Hunter 40.5 Beaufort, SC
Iwould imagine there is a reset button somewhere on the generator itself. That would be the first thing to check.
JamesG161
Feb 14, 2014
7,756
Hunter 430 Waveland, MS
AC on your boat is very complex.
1) Shore power off
2) Shore power failure
3) Your ICG controls
4) 120VC Circuits with GCIF
5) Common Ground with DC
6) Controls on your Genset
7) AC Panel Breakers [my H430 has two]
8) Genset Engine status
Jim...
