Since line is priced by the foot not the piece you will still need the same number of feet for both lines, there is no price advantage.Why buy two lines when one will work for both?
Consider stretch characteristics. For a halyard you want as little stretch as possible. For a mainsheet a little stretch reduces shock load on the hardware.No. Separate lines, separate purposes.
This may be the case, although I've rigged something that uses the forestay instead and it works well. I think I'm going to go by West Marine and buy some more appropriately sized lines!Our trailerable H260 has some similarities with a MacGregor I believe. Our headsail halyard and main sheet are both longer than needed to facilitate mast raising. Is it possible there is a similar use for your boat?
Good point. Probably not. I think separate is better.I too thought of the more rigid line for the sheet. My question is safety related: can you safely (quickly) drop your main sail without having to undo your “sheet”? I’m guessing it would be arduous to undo it all then drop your sail in a blow.
I would have 2 lines. Maybe even by cutting down an unnecessary long halyard.
Just a point in sailor speak, lines are characterized as soft or stiff when talking about flexibility and hand, how the line feels in the hand. Sta-Set X is an example of a stiff line, it does not run through blocks easily because it doesn't bend well, it is hard on the hand. Regatta braid is an example, it is soft and fuzzy, very easy on the hand and runs through blocks well.I too thought of the more rigid line for the sheet. My question is safety related: can you safely (quickly) drop
Yes, if I had to undo the halyard to drop the sale while I was using the same line for a traveler, I'd have to pull the line through 3 pulley blocks before I could even untie it. I recognize now that that would be very dumb.I too thought of the more rigid line for the sheet. My question is safety related: can you safely (quickly) drop your main sail without having to undo your “sheet”? I’m guessing it would be arduous to undo it all then drop your sail in a blow.
