Noob. Do you use the mainsail halyard as the main sheet?
Oct 28, 2024
17
MacGregor 1974 Venture 21 Grant-Valkaria, FL
My halyard is SO long. Do you use it to act as the mainsheet also? The way I rigged the mainsheet with a separate line makes no sense to me.
Pictures will help explain your meaning.
Welcome to sailing. As complex an endeavor one can undertake to get back to the simple life. :beer:
-Will
Jun 14, 2004
171
Hunter 260 Portland, OR
Our trailerable H260 has some similarities with a MacGregor I believe. Our headsail halyard and main sheet are both longer than needed to facilitate mast raising. Is it possible there is a similar use for your boat?
Likes: Chuck_FLA
No. Separate lines, separate purposes.
Consider stretch characteristics. For a halyard you want as little stretch as possible. For a mainsheet a little stretch reduces shock load on the hardware.
Jun 10, 2024
261
Hunter 240 Okanagan Lake
I too thought of the more rigid line for the sheet. My question is safety related: can you safely (quickly) drop your main sail without having to undo your “sheet”? I’m guessing it would be arduous to undo it all then drop your sail in a blow.
I would have 2 lines. Maybe even by cutting down an unnecessary long halyard.
Likes: Chuck_FLA
Oct 28, 2024
17
This may be the case, although I've rigged something that uses the forestay instead and it works well. I think I'm going to go by West Marine and buy some more appropriately sized lines!
Oct 28, 2024
17
Good point. Probably not. I think separate is better.
Just a point in sailor speak, lines are characterized as soft or stiff when talking about flexibility and hand, how the line feels in the hand. Sta-Set X is an example of a stiff line, it does not run through blocks easily because it doesn't bend well, it is hard on the hand. Regatta braid is an example, it is soft and fuzzy, very easy on the hand and runs through blocks well.
Line is also characterized by stretch, generally high stretch or low stretch, with low stretch being preferred for halyards.
These characteristics are on a scale and not absolute values, although for stretch rope makers do specify a value.
Jun 10, 2024
261
Thanks Dave
I appreciate that. Everyday I learn something new. I’m also young, I have no excuse to not remember. :)
Oct 28, 2024
17
Yes, if I had to undo the halyard to drop the sale while I was using the same line for a traveler, I'd have to pull the line through 3 pulley blocks before I could even untie it. I recognize now that that would be very dumb.
Jun 1, 2004
8,258
As a precaution to guessing, which will make it likely that you'll do something that might cause harm to you or your boat... would you please, please take an hour out of your day and read up on sailing and rigging a small boat. It's as simple as google searching (how do I rig my small sailboat? for instance.)
