Nonskid
Jimm
Hunter 33.5 Bodkin Creek - Bodkin YC
'89 Hunter 33.5 --- want to refresh and paint to offset from white deck --- looking for suggestions on process and materials.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Likes: Jimm
PaulK
Dec 1, 2009
1,522
Sabre 402 Southport, CT
We found that with nonskid it was not necessary to tip after rolling. We also found that a fine felt short-nap roller worked very well and did not disintegrate after a batch or two the way foam rollers do.
Likes: Jimm
Feb 21, 2013
4,638
If you are considering Kiwigrip suggest apllying some on a piece of fiberglass off the boat to see how you like the finish, surface roughness and cleanability before applying it on your boat so you have an expectation of the result. Kiwigrip has to he tinted to match boat gelcoat color since it is white.
Do the same with Awlgrip paint. Awlgrip can be color matched without tinting.
Then decide which paint system to apply.
PaulK
Dec 1, 2009
1,522
Some people find that Kiwigrip tires out faster than they hoped it would.
Jun 9, 2008
1,850
- -- -Bayfield
It is my experience, if you use Awlgrip, you should put a flattening agent in the mix as even with griptex, the glossy surface can be slippery when wet and it also cuts down on the glare. Awlcat #3 is the converter for brushing or rolling. If starting from scratch on old fiberglass, then the epoxy primer 545 (with converter) is also recommended before the finish coats.
Jan 24, 2017
672
Hunter 34 Toms River Nj
used Pettit topside ez epoxy on molded non skid deck with recommended solvent cleaner before applying. Did not add non skid grit to paint as recommended because that stuff is really hard to keep clean and if you have ever slipped on a non skid painted deck with that grit added to the paint it will scrape your skin off like a cheese grader.
My molded none skid was really slick afterwards and I later lightly went over the areas with Ajax to dull the finish a little and it’s been great
