Nonskid Material
kaatz
Mar 22, 2006
16
-Beneteau -400 San Diego
Where can I purchase the nonskid material for the steps leading to the cabin. I just purchased a 1995 40' Beneteau. Thanks you in advance for your assistance.
Nov 24, 2012
586
Are you looking for the clear strip that has silica embedded in it? A better solution would be to replace it with non skid treads available at WM or other marine stores. I pulled mine a couple of years ago even though they were still functional. They didn't provide enough antislip and wear protection.
kaatz
Mar 22, 2006
16
Thank you for the quick response. I have seen them at WM and will look again. I was looking for original replacement.
kaatz
Mar 22, 2006
16
Nov 24, 2012
586
These are the ones I installed - but mine are white. They look great and much more functional then the Beneteau strips
Apr 9, 2012
16
Beneteau 37 Georgetown, MD
I did not have to cut and fit the ones I linked too. They are perfectly sized for the steps into the cabin. Just clean real well and center them up.
