Thank you for the quick response. I have seen them at WM and will look again. I was looking for original replacement.Are you looking for the clear strip that has silica embedded in it? A better solution would be to replace it with non skid treads available at WM or other marine stores. I pulled mine a couple of years ago even though they were still functional. They didn't provide enough antislip and wear protection.
This is what I was looking for, did you cut to fit?After slipping and falling into my cabin with some wet shoes on (OWW), I decided to upgrade the nonskid protection with a set of Lewmar Treadmaster Step pads. The "Teak" color looked good and blended in with the interior. Some Goo-Gone and elbow grease removed the old nonskid.
http://www.defender.com/product.jsp?path=-1|10918|311409|23415&id=1495827
