Non working microwave
john2
Nov 26, 2022
101
Catalina 310 58 Leimuiden
gas is from Dometic, oven is : Inventum
an update, The oven was a completely useless thing:banghead: A door opening side ways is almost a garantee to get burned by the door.
ripped it out before the summer holiday and found a Samsung which works great .
Mar 6, 2008
1,493
I would disconnect the power chord for 24 hours then plug it back in. Sometimes the capacitors in the microwave keep the corrupted data running and it will not reset. By unplugging for a long time the capacitors will completely discharge and when plugged in it may start to work. You might remove it and take it home and try it at home.
Sep 24, 2018
4,478
Catalina 30 MKIII Chicago
Check the manual for the right button to press or try pressing every single button on it until the message clears. If you're still having trouble after clearing the 8's, check the door switch. As we all know, a microwave won't start if it thinks the door is open
