Non-skid
John
I have a 1978 Catalina 30. The non-skid is yellow, and I would like to change the color. Has anyone done this? What product did you use? Did it change the integrity of the non-skid to a significant degree?
L
LaDonna Bubak - Catalina Owners
Paint
It's really not a difficult process to repaint your non-skid. There are several books that would help (Good Old Boat is like a bible to me). You'll first clean & lightly sand the nonskid you have now. It's molded in and the paint you apply will most likely be slicker than what you have now. That means adding a nonskid additive while painting. Here's what I did: Sand nonskid, wipe with acetone. Mask off entire deck - my preference is fine line tape to get the best edge. It will be difficult getting all the corners rounded - I cut the tape to the shape of the pattern. Maybe someone else has a better idea. I used Interlux Brightsides & it looks great. IMHO, for that old of a boat, don't go with the expensive 2-part paints. They have a pretty wide variety of colors too. You'll also need to pick up some non-skid material. I can't remember the brand I used but it was basically microballoons made for the job. Punch several holes in the top of the can. Use a foam roller to apply paint to a small portion (1-2' sq) of the deck, then while it's still wet, shake on a bunch of non-skid stuff (like a salt shaker). Move to another section & repeat till the deck is done. After it's dried (give it a day), vacuum or sweep off the excess sandy stuff & give the entire deck one more coat of paint. This method of non-skidding (for lack of a better word) ensures a more even coverage of micro-balloons. If you mix it into the paint, it will settle to the bottom & you will constantly be having to remix the paint up. Go check out a couple of boat maintenance/repair books and find one that you like. It'll come in handy on all your projects. LaDonna
R.W.Landau
I agree with LaDonna
Painting is easy and if done right will look as good as new gelcoat. I used the Interlux Brightside one part paint. I also used their Polymetric nonskid. I painted a first coat. After some experimentation with how much non-skid to use, put on the second coat. I painted with a 4"x1"dia. foam roller. I experimented with thew amount of nonskid prior to the second coat. If you don't mix enough in, it won't be non-skid. If you mix to much in, it is down right abusive on feet or deck shoes. I took a second container, put enough paint to paint the non-skid area. Add about half of what they recommend as a min. Mix it and paint on a test panel. Let it dry and feel the non-skid. Keep adding until you are happy with the results. If you go to far and add to much, add some paint to thin out the non-skid. Good luck r.w.landau
