non-skid deck area
C
cee-bee
need ideas on paint removal on non-skid deck areas. most has come off before I bought this O'Day 25 1979
R.W.Landau
Sand
CeeBee, I don't think you have any alternative. I think you are going to have to sand. I am assuming that you will paint the topsides again..... Sand with 40 to 80 paper and remove most of the non skid(all of the paint). When you repaint, make sure you add nonskid (polymetric) to the paint in the nonskid areas. I say sand, because the other paint did not bond and it is probably because of poor prep. You now pay the price to remove their mistake and prep properly. If you don't get all the old paint, you will see the new paint job fail when the old one continues to loose it's bond. Don't worry about the sanding off the non skid. The deck will not be any less structurally sound. Good luck, I am in the same situation, but it is the first time my boat is being painted. I am finishing the prep today and waiting for 50 degree nights to paint. r.w.landau
C
cee-bee
true grit
thanx, for fast response,R.W. sanding for the sake of good adhesion makes the most sense. I have an area which I am going to try Interstrip w/ a bronze brissle brush. If prior coat was as poorly prep as it appears. I may have a long shot at salvage of the base gelcoat mold in. I had decided to use "polymetric" in,even if I am able to reach original without compromising mold character. This is a aggressive molded in non-skid in original form. I hope to meet or exceed that with the much needed cosmetic upgrade, by useing the non-skid additive.Best of luck on all, those 50's... farenheit that is,gotta be coming sometime
