I have started spring cleaning. Every year I scrub the non-skid surfaces and get the grime off. Is there any wax or sealer I can get to make the job easier than all the elbow grease. also, What are your recommendations for a good hull wax?I want to add that for the cleaning part I use Oxalic acid(wood Bleach). It has no odor. It is not soap although you can add soap to the mixture. I use about one heaping tablespoon per gallon of hot water. The grudge and gray pollution from the soot in the air comes right off. Wood Bleach(Savagran) is about $6.00 for a 12oz container of crystals. A tub will last 5-6 years.Starbite boat cleaner contains oxalic acid. a quart costs $7-8 bucks at wallyworld.
