NOCO charger and commissioning new batts
Jun 5, 2012
153
Catalina 30 mkI Victoria, British Columbia
Maine, have a question on commissioning and breaking in a new set of batts.
Background for you first:
They are Costco 6V GC2's and replace a pair that have been in service since 2012. The old ones were still working fine, but are being replaced because I haven't been able to treat them with the respect they require. I'm on a mooring and up until this year have only had a 60 watt PV panel with SunSaver 6. With these components, I knew I couldn't equalize from solar and we never go to a dock when out, so literally the batts have not been equalized since 2012. This winter I've added another 60W panel and switched up to the GV-10 for a charge controller. That should get me to where I need to be charge-wise.
The new GC2's are sitting on my bench and I want to give them a commission charge, then break them in. Costco has "no information" on who actually made the batteries, so I cannot be sure of the optimal voltage settings. (Because of this I also did not order the GV-10 with custom settings.) What do you think about me using my NOCO G3500 charger to do the break-in?
https://no.co/media/nocodownloads/format/g/3/g3500_user_guide_v2.0_f.pdf
If I set it to think they are AGM batteries I can do 14.8V @ 3.5Amps. This would get them charged up, though I know that all of the cells might not be perfectly balanced... Then I could switch the charger to "12V Repair" mode which would hit them with 16.5V @ 1.5Amps. Maybe leave this on for 15-20 minutes?
Ideally, I would have a Mastech charging unit that I could control everything, but they're expensive up here in Canada. And I'd obviously much rather use the tools I've already got!
Cheerio,
Mike
Jun 5, 2012
153
Anyone else....?
I know the Costco batteries aren't the best, but it's what I can afford...and even under my previous "abusive charging conditions" the last pair was still working fine 4 years on.... Now that I have better charging I'm sure I'll push these out to at least 6 years.
I just want to make sure that I commission and break them in properly.
Feb 6, 1998
11,760
Anyone else....?
You won't be able to do much with that charger. Just cycle them deeply, to about 11.7V, then recharge to 100% a few times. If you have the ability to push them to 15.5V for an hour or two that is great but the Noco chargers are what they are, lots of marketing glitz and glamour but little substance. Before you equalize any 6V battery at 12V nominal (in series) disconnect the batteries and let them rest for a minimum of 24 hours and test the resting voltage. The batteries should be within 0.5V of each other but preferable 0.2V or less. If they are off my more than this they are out of balance and should be charged in parallel at 6V nominal to get them back in balance or one battery will be in excess of 16.0V while EQing.. Series batteries do not self balance and we see quite a few out of balance series wired batteries because they were not properly commission charged. We parallel charge, to balance them, for all series batteries, before we install them..
Jun 5, 2012
153
Thanks very much. Will do.
Hey - something that hasn't made sense to me for a while - how come documents, such as the Ample Power Primer, etc recommend breaking in batts by drawing them down until voltage reads 10.5 (sometimes I see people who tell you 10.7V too I think....) Won't that destroy the battery? Other documentation - like eMarine's Battery Maintenance 101 sheet says a battery is completely discharged at 11.9V.
I'm missing something here that is obvious to most people......
