BP
Peggy, It is our first season with our recently purchased H34. I thought it would be as simple as filling up my fresh water holding tanks, drain, clean out, and fill again. However, I cannot get water pressure to any of my faucets. The pump will run continually.So, I dropped the line between the port holding tank and the water pump, and black crud flowed out. I figure this is throughout all my pipes, and wanted to find out the best way to clean the pipes out, or would it be better to replace?Also, I read your reference on fresh water maintenance,and was informed about using bleach in the holding tanks to clean them out, but have a level of panic when you mentioned that bleach is a corrosive ingredient and should not be left in the tank over 24 hours. I was informed that it would be fine for the week. I used about 1/2 gallon in each tank at 30 and 35 gallons in size.I have turned a headache into a disaster?Either way I am looking forward to any or all thoughts on this.... Only way to learn is by doing!Thanks Pauls/v The Regina Avery
