No Power to my A/C Panel
Hunter 33 Seattle WA
Hi, I recently got my boat back after some work done by a new yard. Shortly after I got it back, I noticed there was no AC power at my AC panel, there appears to be power to the plug. I checked and cycled the AC breaker/Reset in the Port Lazarette. It seems like it should be something simple and I am wondering if I am missing anything. The boat is a Hunter 33, 2005. It has relatively few hours on it. No work was done to the electrical system.
Any ideas out there?
Thanks
Oct 3, 2014
261
Marlow-Hunter MH37 Lake City, MN
Do you have a voltmeter? Where exactly have you tested? Test on BOTH sides of the main breaker in your AC panel. Can you test for voltage at any point between your shore power receptacle and your AC panel main breaker incoming terminals?
7,730
Alden 50 Sarasota, Florida
Most Hunters of that era had a breaker on the panel where the shore piwer plugs into the boat.
I will also look for another breaker and a reset on the plug.. Good idea, I did not think about that.
