In another thread I asked if I had made a mistake buying my Newport 17. You guys set me straight and now I am on the right track. I am going to use this boat to relearn to sail, learn how daysailers are built and how to repair them. I will make mistakes but buying this boat was not one of them.
I took a closer look at those things that I thought were big issues. I put them in the proper perspective and priority.
Loose bow eye. I tightened it from the outside. If it comes loose again, I will go inside and tighten it.
Mast foot fiberglass. I took a closer look, especially inside. No damage inside. So when I feel like learning about fiberglass repairs on curves, I will patch it up.
Motor Mount – I put 230 lbs on it and there was just slight flex in the transom. The gel coat cracks never opened up. I will fix them when I feel like learning gel coat repairs.
This is going to be a learning boat. To sail and to make repairs.
I took a close look at the motor mount plate. The plywood was delaminating and the bolts were rusted so I decided to build a new one. Glad I did, take a look at the first photo. Laminated some plywood together, epoxy coated it and installed it with new SS bolts.
Then I decided to take it for a ride. No sails, wind was too gusty for first time solo sailing. I just motored around, getting use to the boat, docking with motor power and pushing winds, and getting it back on the trailer. I had a blast being on the water. Photo 2 shows how nice it was. Photo 3 shows how low the long shaft motor sits. Is this an issue?
Some suggested I drop the keel and check the pivit bolt. I am going to do that this weekend. Thanks to Randy L for making drawings showing the original keel hoist system and his modified system. When I drop the keel I will consider replacing the wire rope with Amsteel line.
Basically I wanted to say Thanks Again to all those who help me get my mind back on the proper priorities.
I do have some rigging questions but will put them in a seperate thread.
Thanks
Ward
Thanks
Ward
