Parke Davis
Since I bought my Catalina 30 last spring, I have been trying to figure out why I get almost no hot water from the hot water tank even after running the engine under load for 2 or 3 hours. I've blown out the heat exchanger coil in the hot water tank & the two feed hoses from the engine, changed the antifreeze & checked the thermostat (rated at 160F / seems to work). The engine running temperature stays at 160F and both hoses into and out of the water tank seem hot and almost the same temperature. Someone has suggested the following list of possibilities:new radiator cap -can't see how that would help new thermostat - guess I should have a spare anywayfresh water circulating pump problem?calcium/lime build up on the outer surface of the heat exchanger (boat is 10 years old?)Does anybody have some suggestions or similar past experience?Thanks Parke
