I think viewing DIY projects as an excuse to buy new toys is a healthy mindset... my wife may disagree!...
Furthermore, to the rest, i've decided to buy a positive air pressure respirator and compressor for it. its 400 bucks but enh. its a useful tool right? lol. that plus paint and i'll still come in under cost i think what i have budgeted for the paint. i round up, aggressively, for these boat projects.
https://www.amazon.com/Supplied-fre...4144045&sr=8-1&keywords=breathe+cool+air+pump
https://www.zoro.com/allegro-constant-flow-airline-respirator-12-psi-9920/i/G4838486/
So there's that![]()
Yes but... when you are done fairing you can overcoat with unfilled epoxy, sand smooth and paint (With bottom paint). Or maybe you need a primer. I'm not against barrier coats but is an awful amount of work to do well and it will take up considerable time.thats the thing shemandr - i have some areas around the keel and the rudder tube where the fairing compounds are cracked and i need to grind into them to glass it all back in proper... at that point i have to put the barrier coat on at least in places.![]()
Any job that requires a new tool is job worth doing.thats the thing shemandr - i have some areas around the keel and the rudder tube where the fairing compounds are cracked and i need to grind into them to glass it all back in proper... at that point i have to put the barrier coat on at least in places.
