No AC power. Where are the breakers/fuses.
21
Hunter 33 St. Joseph, Michigan
I have a Hunter 33 (1982). This is my first season with this boat. We plugged in the shore power but have no power on the boat. I can't find any breakers or fuses. The boats wiring diagram doesn't show any either. Anybody have any ideas? Already tried different power cords and power supplies.
Mar 18, 2010
91
O'Day 222 Smith Mountain Lake, VA
Cheeck the Port Side Quarter Berth
I looked at the 81 Hunter manual that are callout out in this thread: http://forums.hunter.sailboatowners.com/showthread.php?t=111652
For the 33, it show the switch panel near your stove. The AC from the Shore Power Connector goes directly to this panel. Are you sure there are no breakers there? You could follow the wiring under the cockpit to the breaker box. There MUST be one..:eek:
Jun 7, 2004
265
- - Milwaukee
On my 356, if an 120 outlet blows, they all blow (like the time I dropped the drill in the water) (good thing it had the cord attached to pull it back out). There's a reset button on one of the outlets, near the nav desk, that resets all the outlets. Odd, but it works. May or may not be what you have, but thought I'd mention it.
garyc
Oct 4, 2008
63
Hunter 27-76-84 mallets bay,vt
look for the last breaker at the bottom of the breaker panel it should say ac
Jan 14, 2009
12
2 33 Port of Newcastle
Check on port side under aft bunk
I have the same boat. My breaker panel is on the port side, aft of the stove.
Left side is DC panel. Right side is AC
Top breaker is AC Main.
