I recently purchased a beneteau 40. it came with a 5 hp Nissan 2 stroke. i have removed the lower unit and replaced the impeller. I cannot reassemble the lower unit. i have the gear shift aligned (i think). The top of the shaft is not engaging with the motor. I am about 2 inches short. I taken the spark plug out and manually moved the cylinder to see if that would get the shaft to align. no luck. Any ideas?
Thanks
Thanks
