Ok smart people I've had a little 5hp nissan/ tahatsu that I changed impeller cleaned flushed cooling passages and test run in fresh water but when I put in salt water it stops pumping water and over heats. Tried changing impeller again to see if it's slipping on hub. But stops pumping water 10 min after I leave the dock every time. Any idea what it is do they have thermostats is the salt clogging it it will idle all day at dock used a whole tank of fuel one day and dock mates kept telling me I left motor running but soon as I left dock quit pumping and overheating
