Nicro Powervent 3000 Troubleshooting
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Greetings,
I have two Nicro Powervent 3000 solar powered vents. They do not work. I bought replacement C-cell NiCd batteries and replaced one in one vent. No joy. I have voltage on the solar cell, and battery voltage, but in spite of several depressions of the power switch, the fan won't spin.
The electrical part is potted, so I can't easily probe to see what's going on.
Does anyone have any experience debugging and fixing these?
Know where to get parts, e.g., solar cell "O"-ring/gasket?
Thanks,
jv
May 27, 2004
2,059
The world wonders the same thing. Mostly, the answer has been "You can't".
But maybe there's a new solution out there.
RoyS
Jun 3, 2012
1,742
There is a learning curve with power vents that runs like this: How many are you going to buy before you give up?
Likes: Gunni
Rick D
Jun 14, 2008
7,203
Went though the same. Replaced it. In general, they seem to last five to seven years. Just consider it a replacement item like your water heater. It's worth the expense for me to have some ventilation on the boat. I have been using them for almost 40 years, starting with a wooden boat.
jviss
Feb 5, 2004
7,090
Thanks Rick. Unfortunately, as far as I can determine, the PV3000 is no longer available. I've written to Marineco about parts, etc.
The thing is, I have them in the two, main, overhead hatches in my boat, which are Lewmar Ocean hatches. I would prefer just plain windows, without the vents, and I may someday buy new lids, which would add up to about $800. Meanwhile, I just decided that if I have them, they may as well work! I bought 3000mAh NiCd C-cells on Amazon, and went at one of them. As I said, no luck. The guts are potted, or at least coated with some kind of clear potting compound. I wish I knew what would dissolve it without ruining the plastic. It's got to be the motor, or the switch, or the intervening wiring. I would think that even if the diode was blown, the charged-up NiCd would spin the fan.
Would like to fix them! (Those motors are cheap and available.)
jviss
Feb 5, 2004
7,090
I will, Rick. Do you know, do the motors on these fail? Switches? Do you have any old parts lying around? :)
Rick D
Jun 14, 2008
7,203
No I don't know. I do know the motor would not spin with the new battery installed, so I assume it was that, but as I recall, the motor & solar leads were potted. I tossed the remains, so none to offer.
