next nav problem
Sundance Sundance 20 Weekender Ninette, Manitoba, Canada
In the spirit of boring winters up north, and the fun had on a couple of other threads regarding navigation, here is a fairly simple problem based on time speed distance caluclations, and a few vectors. At 1300hrs you are at point A, with a heading of 035 deg True at a speed of 5.5 kts. You are following a coastline on your starboard side. Using your trusted chart (you don’t need a chart for this exercise), you see that a safe harbour is coming up in a few hours. The red buoy marking the harbour entrance according to your chart bears 042 deg true from your current position at 1300 hrs, at a calculated distance of 22.5 nm, using your dividers. Also using your chart you determine that a point of land is marked by a light which bears 038 true from your current position at a distance of 15.5 nm, again measured by your dividers. (Note both of these are true bearings from north, not relative bearings from your ships head.) You determine that by 1600hrs at your current speed, you should have cleared the point of land, and even though somewhat distant, you can make a clear run for the buoy and the safe harbour beyond. Here is the question: At 1600 what is your new heading to intercept the buoy and at what time will the buoy pass at your starboard hand?
Ross
Jun 15, 2004
14,693
Good problem. I am watching Boston Legal
but have a short day tomorrow.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
GREAT explanation!
At 1600 hrs, you bear to 060 deg, and your buoy is 6.5nm away. You will pass it in about an Hour and 10 minutes. That land barrier had nothing to do with solving the problem. However, it is helpful to avoid them :)
May 6, 2004
916
Hunter 37C Seattle
Roger no answer just a question
You are on a 035 heading, with destination at a 042 bearing and need to clear a point bearing 038. If I dont' change my heading to 038 I will take the long way around. True? If I wait until 3 hours have passed before changing course, I will be a 1nm past the light on a 035 heading , True? The light is 15.5 nm from current position and after three hours I will have traveled 3 x 5.5 = 16.5 nm) So under your situation the light at the point is not a reference point, True? On a chart I could fix a point 16.5nm off my bow with a heading of 035 and then determine the bearing to the marked harbor light. But I can't do the calculation without a chart. I would alter heading to 038 and then plot the bearing between the two fixed points ( the two lights/buoys) Some one post a graphic of the solution. Thanks
Ross
Jun 15, 2004
14,693
I used an engineers scale and a protractor
and came up with the same results as GuyT in #3. It would be posible and safe to start the new course a little sooner but not a great benefit.
