Okay Newport owners, convince me to buy a 1988 Newport 31 over a 1985 Catalina 30. The Catalina has rediculous specs, i.e. new sails, new running rig, new canvas, new ss shaft and curlass bearing, etc...!!! The Newport just gets my juices flowing though. This will be my first boat. The only advantage on the Newport is a diesel forced air heating system, 2 owner and only fresh water, not a dime a dozen like the Cat, and Ooooh Laa Laa...!!! HELP...!!! Oh, and the Cat is $5k less.
Just curious... why move down from a 35 footer?
And while at their ages condition is
very important, pick the one that sails better. Not sure about the Newport 31, but the older New. 30 was a very good (!) sailing boat.
Another key difference is that the Newport's used a flange hull to deck joint with thru bolts, and the Cat used a shoebox joint. Having said that, Newport was infamous for poor caulking in those joints. Go figure!
Forced air heater note: check on the actual model. Some older ones are nowadays hard to source parts for, and others have no problem.
Both boats are old enough to potentially have water in the deck coring, and a good survey will tell the tale. I hope the previous owner(s) have rebedded all the deck hardware. Both craft should be on their second set of standing rigging by now. Ask about these preventative maint. items, and do not let the broker give you a vague answer... unless that vague answer is accompanied by a 5K price instant reduction upfront.
If you want an excellent survey, contact Alison. Best in the NW. Period.
http://www.alisonmazon.com/
(I have no personal or business connection.)
Engine note: Both companies used a lot of Universal engines. An '88 model should normally be an M25XP, 23 hp. I would doubt that it would be older M25 @ 21 hp. Anything's possible, I guess. ??
