Newport 27 Hatch
Dec 15, 2020
1
Newport 27 Oyster Point Marina
We are looking to repair or replace our companions way hatch. We are in the SF Bay area.
Welcome to SBO “bad fish”.
:plus: On the pictures. Keeps all of us from guessing what you mean.
Johnb
Hunter 37-cutter Richmond CA
Tap Plastics is your friend. I use the one in El Cerrito. Just had a replacement made for a cracked hatch board
MitchK
Sep 22, 2017
102
Capital Yachts Newport 28 Burbank, WA
Badfishtoo,
We are in the process of building a temporary hatch for our N28-II. I am building the temporary hatch so that it is fully functional as it is likely to be on the boat for several months as I work on the original one. Ours is fiberglass that used to have what appeared to be a plywood insert on the top. I finished pealing the plywood layers off a while ago, and it definitely needs attention. I will be adding another layer of glass cloth and mat, then building up the top surface with teak decking slats. Here is what ours looked like after removing the plywood.
dsmoll
Dec 16, 2020
23
Cheoy Lee Bermuda 30 Hadlock, WA
"Sailor James" on youtube has a great series on the replacement of their forward hatch. They replaced the hatch with a new Lewmar. Ended up looking really nice. I'd go that way. Would look nice on a N27, especially if you went with a more flush mount and got rid of the box riser.
We had a Neptune 24 before our current boat. It had a really nice translucent fiberglass hatch that fit the contour of the cabin top...I could never figure out why they didn't do something similar on the N27 since the topside design on that boat is so sleek looking.
