1. I'm looking to install two air conditioners. Does anyone have this boat that can tell the BTU's of the two units. Also does anyone have any experience installing them that could pass along any tips. I got a quote of $20,000 to install both... yikes! lol. I'm pretty handy and my father is an electrician. I will get the local marina to put the through hall in for the water inlet.
2. Does anyone have a generator and if so what type and size?
3. I will need to put a new 30 amp connect and will place it next to the 32 amp (I'm going to change this to a 30 amp along with changing out the end of the cord). I have the two birth set up with the storage room. I will still vent the storage area as I'm changing it over to a third room when needed. I was going to put a separate panel in the storage area to handle the air conditioners and also a few breakers for outlets in the bathroom and storage area.
4. My bow sets pretty high out of the water. I ordered a water tank to put under the front birth. Maybe some more chain on the anchor? Any other ideas?
5. Best place to get a spinnaker? new or used. I have a code zero and was thinking of just using that halyard for both as a separate halyard would require something at the top of the mast putting out in front of the other two furling sails.
6. Should I vent the cockpit area and get a full canvas enclosure with zip offs for hot and cold days?
7. Opinions on adding davits / solar panels for a dingy?
8. Plan is to keep learning to become a better sailor on lake erie for the next full year and head way south down the coast after next years hurricane season. Any other additions to the boat you can think I'll need?
Thanks ahead of time for any help.
Larry
Larry
