I am starting my first sailing season on a 2000 Hunter 460 with in mast Furlin. I appreciate any guidance on two issues I am having. I previously had a Beneteau with in mast furling without any issues.
Issue 1: when unfurling the main using the out haul it jams. When it starts to jam, I pull the unfurl continuous line and it will continue to unfurl. Is this normal operation? I was doing this at dock with no wind. I want to understand this operation before I am out in normal wind conditions.
Issue 2: When furling the main from cockpit the continuous line slips through reefing winch even with minimal tension on the out haul. It works if I use the winch handle on reefing winch, but this defeats the intent of furlin from cockpit as a single hander. Am i doing something wrong or do I need to adjust something or replace the continuous line? Any advice is appreciated so my first sail will be enjoyable?
Thanks
Kevin
"Knot in the Beach"
Thanks
Kevin
"Knot in the Beach"
