Newbie: plastic ring around emergency tiller
52
Hunter 27 MD
Newbie. 82 Hunter 27. Wheel steering. Back where the emergency tiller shaft comes up through the deck, there is a plastic "doughnut" that cracked - below is picture.
So the shaft comes up vertically, then there's a bolt horizontally through this "doughnut".
What does this doughnut do ? It is not load bearing vertically for the tiller, right ? If I take the horizontal bolt out, the tiller won't fall out, right ?
I guess I can make a replacement part out of stock nylon or polyethylene.
Appreciate any thoughts.
May 17, 2011
10
Hunter 27 Clearwater fl
It is a wear ring and yes it keeps the tiller from lowering...search for pictures of the tiller thru hull and the tiller stuffing box...the pictures appear in the Hunter Manual that came with the boat...
Jan 9, 2013
76
Hunter 27 Mooresville, NC
Nothing of any real value to add , except that I have the same boat...with the exact same issue., and the boat is new too me as well. Be aware that the ring also encapsulates the bolt, so without the ring the tiller can hang up as you're turning the wheel. Not a major issue, but it'll make you wonder unless you happen to glance down. I left the bolt in: my theory is that if I'm not sure it isn't critical...it stays in case it IS. Let me know if you find a replacement part! Thanks-
Jun 21, 2009
110
Hunter 27 Sparrows Point
I have tiller steering, and my ring went up a couple seasons ago as well. One of my local marine shops was able to mill me out a new one out of scrap aluminum stock. It will certainly outlast my boat, and me, my great grandchildren, the next ice-age...
Hunter 27_75-84 Wilmington, NC
That material is DELRIN and your local machine shop should be able to make. I paid $75 last year.
