G
Gerry Bogert
My depth transducer is not working and requires replacement. I purchased the Raymarine ST60 package with speed, depth and wind. I am installing the transducers in the same locations as the existing equipment. The transducers are too tall to be installed under the floor grating. Raymarine makes low profile versions. I can not get to the boat to check the hull thickness or hull to grate height to make sure these will work. Has anyone replaced the transducers with the Raymarine ST60 package? What height transducers did you use (part number if available)? Any information on installation would be appreciated.Thanks,Gerry
