Tie a knot in the Main sheet???????
Sorry to bust your bubble Steve, but Don, DON'T TRY THAT MANUEVER! You should NEVER allow your boom fly while jibing... especially in strong winds! Maybe the knot will stop the sail from hitting the shrouds, but who cares about that? When the knot hits the sheet block, it might rip the damned block right off the traveller... or the boom! IN either case, you're beat!If you are on either a broad reach (wind over the starboard quarter) or a run (wind directly aft), and your mainsail is to port, then turn to starboard in order to come up into the wind. This makes it unnecessary to jibe. As previously explained, let your main out if you start to heel too much (It should already be out if you were on a run!). You can also let the jib out a bit if the wind is really that strong. However, if you really must turn to port under the above conditions, then sheet the main in fully BEFORE you begin your jibe and let it out again as soon as the wind catches the port side of your main. You should never allow your main to fly around loose during a jibe - eventulally, YOU WILL BREAK SOMETHING, and possibly hurt someone, too!As far as shipping the sails go, I can't understand why people are telling you to heave to. Unless you have roller reefing, you should (IMHO) be in irons (directly into the wind) when you drop your main. The sails slide down so much easier that way. With a stiff breeze going, you'll need to fire up the engine to keep you in irons while the sails get put up; otherwise, they'll be blowing all over the place. Do you have a good book on sailing? May I suggest "Sailing Fundamentals" by Gary Jobson? It is the official manual of the American Sailing Association and the USCGA. Studying this book will be of immense help to you AND your new boat! ENJOY!Jim maroldos/v: Lil' Wass Ett
