Jumping In With Both Feet
Hey Phil, I've read your query a few times and was hoping someone else would wade in...8^), guess not. Most people start smaller and work up, and most are probably thinking "wow, no sailing experience, and he buys the grandaddy of all O'Days" (I know I did). Well ya did, so you better jump on the learning curve train, cause you got a lot to learn.You are starting at the right place, here, but I would buy some further references. Get Nilger Calder's "Boat Owners Mechanical and Electrical Manual", and keep it close buy (or anything from Don Casey). You need to know about "through-hull valves", and bottompaint options and the myriad of other sysytems this boat has. I might also buy some professional guidance from a marine surveyor (I assume you had a survey done?). Have him spend a day with you onboard pointing out the "systems" onboard. How to maintain them and what to watch out for. Also buy a couple of hours of a diesel mechanics time or take a diesel maintenance course. The engine will be the most important and expensive piece of equipment onboard. Gonna repeat myself here but buy or have a knowledgeable sailing guru take you out on your own boat to show you how to "sail her". Your not going to learn sailing by simply reading about it. Practise, practise, preferably on a smaller more forgiving boat, and have that guru show you how to dock her, especially in close quarters. Can you crew with someone elses boat? How did you find an O'Day 40 in England? Can't think there would be many across the pond.Don
