K
KennyH
I have always had larger boats with marine heads. My Hunter 25 has a portipotty which has been fine until now. I visited my boat and found green water in the bilge which is normally dry. I checked the clean out for the potty and it was tight with no apparent leak. I am guessing the leak is between the top area and bottom storage. There was green water under the unit. May have left green water in bowl but I dought it. Maybe the green water seeped into the bowl. Maybe the bulb has a leak in it. Is there a gasket that goes bad? Could not seem to make it leak again so a passing boat may have rocked it causing the leak. Any ideas? Thanks.
