H26 Centerboard
Some people find it necessary to use the winch but I find it comes up fairly easy if you are underway. Just give it a steady tug and the water pressure will help you. I think there is lots on this subject in the archives and suspect that if you try to cinch it down too tight, you'll stress the rope and have to eventually replace it.Also, let it down gently, you can damage the board or chip the gelcoat at the pivot point.
