new sails vs used ?
515
Kittiwake 23, Irwin 43 .. Indianapolis / indianatown, fl
hello all
i am in need of a main sail and jib for my sailboat. i have seen many listed on ebay for sale, but they are not exactly the same size i have as old ones. is it better to buy a new sail, or can i get a used sail close to the same size and it work for me. i have an older MacGregor 25 sailboat. it is a project boat, and i have all my running rigging to buy yet. ropes, blocks, cleats, and more... also trying to find a good source for the running rigging to buy, without tearing a hole in my wallet.. any help or suggestions will help alot..
thank you
Jess
Dec 2, 1999
15,184
You can get a very good price on running rigging from this website.
Check Minnie's Yacht Surplus, Bacon Sails and The Sail Warehouse for used sails.
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
Ive used their line calculator a few times, changing the various options. If you can make your own splices and re-use your old shackles, you can save a bundle.
Beneteau 323 Annapolis MD
baconsails.com lets you look at their inventory of consignment sails... and more.
Oct 11, 2012
56
Clark-San Juan 23 Kings Mountain N.C.
I would go with a used sale based on price. I am sure the boat will have other issues that require your attention and money. Put it together and sort it out first. You can buy new sales after the fact. I may have a used sail for your boat but want to see what brand and size it is.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
You might want to check and watch the SBO classifieds too. I've seen some nice gear for sale for good prices.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
New sails are like having a brand new boat, performance wise, there's just no comparison. That said, if you can find a 7+ used sail that fits, you can save about 70%. Minneysyachtsurplus.com, usedsails.com.
Is your boat a masthead rig or fractional? If it's masthead, you'll be looking for a mainsail about 25ft or less on the hoist, and 10.4ft or less on the foot.
The masthead jib should be around 28ft on the hoist, and 11-14ft on the foot.
The fractional rig takes a mainsail about 25.4ft x 9.75ft. The fractional rig jib is about 22ft on the hoist, and 11-14 on the foot.
Dec 7, 2012
515
hello
thanks for the advice. i will give it a try.. i am not sure what fractional is. can someone please explain that to me.
i measured my mast, it is 28-0, and the boom is 10-6. i have a harken furler and it measures 22-8. i am still trying to understad how to measure the proper sail size for the main and the jib. i can handle the ropes ok, but i need pleanty of hardware like blocks, cleats, and such.
thank you
Jess
May 27, 2012
1,152
You need very accurate measurements. Don't oder off any charts, a PO may have altered something. Heres how to measure.
http://www.secondwindsails.com/measurement.php
Someone here mis-measured before ordering new sails and they came too long. Very expensive mistake as the sail maker isnt going to refund for those kind of goofs.
A fractional rig the fore sail doesn't go as high up the mast as the main.
Jun 21, 2007
2,117
One item about used sails: When you find one that you like, its OK if a little too small. But never too big. If for instance you find a jib who's luff is say 3"-6" shorter than perfect, the main effect is maybe a fraction a knot slower in light/moderate winds. And none at all when the winds are fresh since the boat will be limited by hull speed and excessive heel anyway. But a slightly small sail will be plenty OK for recreational sailing. However if the luff is too long by the same amount, then you've got a baggy luff that won't tension ... Looks terrible and performance will be bad ... And an expensive visit to the sail loft to have it cut down to size. My current mainsail is a second-hand full battened one previously on a Catalina 36. It's about 6" short for both luff and foot compared to the spec for my boat. But the sail was in very good condition and 1/10th the price of new sail. Been using it for five years now with many happy days on the bay.
Dec 7, 2012
515
hello all
my main sail is toast... pasts of it are shreaded, like someone slid a cheese grater through it. the jib sail has about 9 small holes about the size of 2 inches in diameter or smaller. i was thinking of using the old main sail for patches to close the holes in the jib. what should i use to bond the patches to the jib, before i sew them on ?... i was thinking of using contact cement or rubber cement ?.. or is there a better product out there ?
there are so many differant sizes of ropes, ie; 9/16, 1/2, 7/16, 3/8, 5/16/ 1/4, 3/8 .... what size is needed for on a 25ft sailboat with a 28 ft mast. i have been looking at so many chanderies, and ebay, and .... AAAAAHHHHHH .... advice on rope diameters to use and if differant sizes, where for each size. i do not have a big sailboat. my baby is only 25 foot long wiht a 28 ft mast... the only thing i want to change is i like the idea of having a bowsprit, and move the forestay with me furler out onto the end on it, this will allow a larger foot on my jib and genoa jib. and if the distance is write, it will allow an inner headsail too. but that will be a future project,. right now, what rope diameter do i use ? please help
fair winds and good sailing
Jess
Dec 8, 2011
172
Hunter 23.5 New Orleans
trainmanjess said:
hello all
Jess
As was said earlier, google Bacon Sails. Bacon's on line computer knows the proper dimensions of your boat's sails and will tell you what used sails are in stock to fit your boat. Bacon also tells you the used sail condition and in my experience are conservative in their evaluation. You will receive the sail on approval and if you don't like it you send it back. As yours is an older project boat, I assume you don't now plan on doing any racing. For reaching from here to there and back, good used sails will move your good old boat just fine.
Kind regards
Hugh
Oct 26, 2005
2,057
Trainmanjess,
3/8" is a good size line for our size of boat. I'm using double braid (sta set) for my halyards, mainsheets (2 on mine), vang and CB line and it's plenty strong and big enough to feel comfortable. Biggest reason I used this is because I had a big hunk on my shelf. My jib sheets are something softer to the hand and 1/2 diameter and I think they are regatta braid.
Some may argue for no stretch, day glo, j-lo whatever but I'm not an olympic racer and am ok with not having the "VERY BEST" according to Sail magazine.
I agree with anchor to not use someone elses info and measure the sails yourself.
Do the sail that came with the boat fit right? You can just measure them (all 3 sides) but stretch them out first.
RichH
Feb 14, 2005
4,773
Best way to 'glue down' before sewing: http://www.sailrite.com/Seamstick-1-2-Super-Basting-Tape-by-3M-60-Yds (available in various widths). This is clear double sided adhesive tape. You can probably get an equivalent at a large box hardware store ... used for sticking rugs to flooring but is HAS to be 'clear' tape.
No need to sew down if the patch is NOT along or near an edge, but best is always to sew.
Next best is clear silicone caulk, spread *thinly* on both surfaces and with the surrounding area very carefully masked with tape to prevent 'smears' of caulk. Allow to fully cure before sewing.
Next after that is FAST CURE 3M 5200 caulk. Same as above, need to carefully mask, etc. It will 'peel' off of dacron sail material ... with difficulty.
Contact cement, rubber cement, automotive 'headliner' spray on adhesives will eventually turn BROWN and 'show through' the sail material.
