Simplest mast raising
A mast crutch is a must, without it, will take 3 men to raise a mast on a 22 foot boat.Go to local hardware, purchase 100 foot cheap rope. With base of mast attached in cabin unit and top of mast supported by the mast crutch, attached end of 100 foot rope to bottom end of forestay. With a second 3/4 person, wife, girlfriend or teenage child of at least 100 lbs., stretch rope out overtop of tow vehicle into the parking lot as far as the rope will go. You straddle the cockpit benches and lift the back end of the mast over your head and walk forward until you reach the back of the cabin. At this point the mast should be at an angle of 20 to 30 degrees, transferring a lot of it’s weight to the cabin top. The very top of the mast is now very light. How light? Try this. With the mast attached to the cabin top and the mast setting in a crutch at the stern, stand on the cabin top and try to lift the mast at this point, two men can not lift it. What 300, 400, 500 lbs. Stand in the middle of the cockpit and lift, pretty heavy but at the back of the cockpit the lift is only 40 to 50 lbs. and as you walk forward the mast does not get real heavy. At this angle, one person standing on the cabin top can hold the mast where before it weighed 300 to 500 lbs. Wonder what the top of the mast now weighs? It is so light now a 3/4 person can now pull it all the way up, standing 100 feet in front of the boat. 100 feet in front of the boat has a good leverage angle for pulling the top of the mast.As this 3/4 person raises the mast you can check for lines being hooked in the cockpit, 2 out of 3 mast raising this will happen.With the 3/4 person holding the mast up from 100 feet away in the parking lot, attach the two front baby stays. These two front stays will hold the mast until you attach the forestay.Reverse everything for lowering.A Mast crutch which is needed for all other way of raising, 100 foot rope and 1 3/4 people. Simplest method known!Done this; plugged cockpit scuppers, added 5 gallon clean water, dumped in one med bottle Windex and box of baking soda. Used brush on cockpit benches, rinsed with two changes of clean water. Clean feet, clean sail, clean cockpit, had to find place to hang sail to dry.
