You guys have to know by now that I'm crazy... like coo-coo for cocoa puffs right?
I guess I just like a challenge, and I can't resist any opportunity to wield my TIG and Plasma Torches.
So there have been many threads and several dozen comments about getting a replacement for C22 swing keels. Seems like the only plausible 3 solutions are;
1. Restore your keel, no matter how bad it looks... it COULD be saved.
2. Find a used keel at a boneyard that is in better shape than yours, then restore it.
3. Open your wallet and bend over, $2.3K plus freight for a new factory replacement.
So this got me thinking, with all the DIY expertise we have as a group; Why can't we come up with a better solution that replaces most of the high cost with sweat equity?
So looking at the original factory drawing got steam coming out of my ears. I could use 10 gauge cold rolled steel (or even stainless if I want to go bat sh!t crazy) and plasma cut all the shapes I need to do a skin over rib style frame, like an aircraft wing. I would weld in the stainless keel pin bushing as well as 1/2" 13 TPI stainless threaded bung for the cable eye bolt. The profile would be accomplished by rolling the steel skin through a roller to give it a light curve and clamping it down over the rib frame to tack weld, then essentially there would be one weld bead all the way round the edges. The lowest part of the keel would essentially have internal compartments that could be filled with lead and plugged off. Then, just clean up with coarse sanding and paint with Interprotect 2000, light fairing as needed.
I'd need feedback and some help from the group. I don't have a factory drawing which details a profile view of the foil. All I have is my own keel, lol! I'm not too savy with computer drawing tools, maybe someone here is? I think if we put our heads together we can figure this out, keep costs to a minimum, and do a kick ass job!
To get the juices flowing here is the factory keel drawing;
