David Walker at Foss Foam told me that they made Hunter rudders from 1978 to 1995, when Hunter took over making thier own rudders until 2002, after which Foss took back making them. My boat had the same water logged rudder issue identified in the survey, and I reduced my offer accordingly. The problem with drilling hole(s) in the bottom of the rudder to let the water out is that the foam is waterlogged and retains the water quite well and doesn't just drain out. It's also (or at least the foam in my rudder was) quite a light weight foam which exacerbates the water retention issue. Hunter also used fiberglass rudder posts/shafts while they were making their own rudders, although I don't know if all of their in-house made rudders had these. These are reportedly quite strong, but are simply glassed internally to the rudder skins, so no internal stringers. I ended up recoring my rudder with 16lb foam, but that was quite a time consuming job - not sure if I'd take that project on again, but it did save me ~$5k. And yes, new cutlass bearing, Volvo shaft seal, etc. "while the rudder was out anyway" added to the project.
