Hi Kevin;
it;s also a very good idea to learn the rule of the road and understand the markers- happy sailing
Wilhelm, V-257
pjacobs55 prjacobs@... wrote: Kevin,
Congratulations on your new boat! You've picked a great little ship.
The Vega is a well thought out design, very solidly built, and will
look after you in all kinds of weather.
My best advice is to find a friend who sails and go out together in
fairly calm weather to get a feel for things. It doesn't take long
to 'learn the ropes'. On my first few forays onto the water I was
armed with a little book called 'Royce's Sailing Illustrated'. It's
full of good info. But I still made every error in the book, and all
in one afternoon!
You won't have to worry about bleeding air from fuel lines as I
believe Nosa has the original Albin 022 gas engine. Air bleeding is
usually reserved for misbehaving Diesels.
It's great to find a boat that has all the documentation for it's
accessories, usually indicating a caring previous owner. But don't
let all that paper work bog you down, as firstly: it's meant for
reference when something won't work, and secondly: it's useful for
preventative maintenance when the weather is no good for sailing.
If you had a survey done make sure you follow any recommendations
made.
The most important thing is to keep her afloat. I check my bilge on
arriving and on leaving the boat. There's always a bit of water in
there, but any sudden change in level is cause for immediate
investigation. An electric automatic bilge pump is an excellent
accessory.
When leaving the boat I make sure all thru hull valves are closed.
When you go out the most important valve to remember to open is the
cooling water for the engine. I hang my ignition key on the valve so
I can't forget to open it!
There's probably a million other things to know, but they all come
with time as your experience builds.
This is an excellent forum. Most questions have already been asked
and are easy to find using the 'search' feature. Another good general
boating forum for information is the Classic Plastic Forum at
http://www.plasticclassicforum.com/
Peter
#1331 'Sin Tacha'
Victoria B.C.
