I like the ideal of a brand new honda,merc,evinrude etc. but dont like those price tags so my next is the tahatsu which ive heard many times over and much cheaper. So whats your thoughts on the tahatsu and also a recommended hp.
Mine are all 4 stroke. I didn't think they had been making 2 strokes for some time. You will get better gas mileage if that is a concern with the 4 stroke. I get about 10 mpg running about 5 kn with a very heavy boat. 2 strokes aren't allowed on some lakes in some states. Make sure that won't be a problem,Thanks sumner and glad to here it, i just found a brand new 2015 electric start 9.8 2 stroke, that the dealer hasnt sold, comes with the normal 3 or 5 year warranty for $980. I think no-matter what ill have to buy it at that price
For me it would depend on two things.Hhmmm on the 2 stroke, i havnt physically put my hands on it maybe im counting my chicken to early! If thats not possible would you buy a 6hp sailpro or the 8hp
Meanwhile you really can learn to live with it. I've done a bunch of testing for ASTM and mags and I've learned how to make it painless:
- Keep the vents closed on integral tanks and portable tanks when not actually running. Even an overnight rain can ruin the fuel. Been there. But no vent = no aging or water pick-up.
- If you have an installed tank, install a vent filter. Less water absorption (less corrosion), less volitiles loss (easier starting), and no chance of salt spray (doesn't take much).
- Use an effective anti-corrosion additive. Unfortunately, they do NOT all work. Biobor EB, Mercury Quick Stor, and Seafoam are proven. Run the gas out or don't--your choice. I see no proof that solves anything. Running the engine every month and using an additive works perfectly. Carbs are not actually clogging on gum these days, they are clogging on aluminum corrosion bloom (aluminum bowls + brass fittings = corrosion).
- Run the engine. FAR more sail kickers and dinghy outboards die from disuse that hours. Try to turn the gas over several times each year. This is also true for non-ethanol gas.
I agree with the "once in the region of theoretical hull speed", and both can achieve that. The difference in the two outboards is before you are there in some tidal current situations. In some of the narrow channels going between the ocean side and the bay side you can be in more or less slack current at one moment, 90 degrees to it at another and then dead against it in a matter of feet and seconds. The larger prop will react faster and allow you to better maintain steerage as this happens....Once in the region of theoretical hull speed, the larger outboard will only result in maybe 5% more speed than the smaller one. ...
Great example of why I dont like analogies.. Current is NOT like a steep grade. It is a body of water that is moving.Kind of like a small pickup with a 4 cylinder and a larger one with a V-8 . Both can pull a heavy trailer down the highway at 70 mph but if they come up against a steep grade the V-8 will not loose the speed as much.
That it is and one that can be constantly changing. Sorry for the poor analogy. It wasn't meant to be an accurate example but to point out that there can be times the larger OB can be of benefit, even if the 6 hp and the 8 or 9.8 HP can take the boat to hull speed,... It is a body of water that is moving.
Say we have two displacement boats similar to what the OP has, One has a 6 hp and another with an 8 hp. These boats can easilly travel at the same speed if its under the theoretical hull speed (THS). Both boats have enough HP to get up to theoretical hull speed and the one with the 8 hp will push the speed farther into THS but this will only result in about 5% more boat speed. For this example, we will round off that 5% and say both boats have the same peak speed of 6 knts.Kind of like a small pickup with a 4 cylinder and a larger one with a V-8 . Both can pull a heavy trailer down the highway at 70 mph but if they come up against a steep grade the V-8 will not loose the speed as much. .
I think you are missing the point I'm trying to make. Sorry, but It isn't what you just posted. I'll try again........The analogy that Sumner used would predict that the boat with the lower HP would to start slow down with respect to the other boat with higher HP as the current increased.. Which is not at all correct.. Its a misleading analogy......
