New self venting fuel caps, pop open at +5 PSI to prevent the tank from over pressuring. Manual override. If you leave your fuel line connected to your outboard in the hot sun it can over-pressure your fittings, cause leaks and even fill your engine with fuel. EPA and CARB compliant. Above deck use only.
Moeller fuel tank.
Moeller replacement gas cap for post 2011 tanks.
Moeller fuel tank.
