New Interior Covering-H25
Sam
Sail a 1978 H25.Want to cover/replace the "upholstery fabric"covering on the interior walls(original).Need input such as what to cover with(more fabric,counter top material,thin paneling,etc).Any suggestions welcomed.
Jay Hill
Try Carpet
I still prefer to touch a wall/bulkhead and not burn my hand or freeze it. Carpet is always comfortable to the touch, easy to install, lasts a really long time with no maintenance, and, if you buy the right kind of carpet, is treated to resist stains and odors. This makes it easy to clean. I love the look of wood, but it requires a bit more maintenance. I'm not sure, however, if there is a specifically designed marine-grade carpet made for such purposes. You might call Hunter support and ask them what they're using in newer models. If you do this, please let us know what they are using. OTOH, if you have any leaks down the bulkheads, carpet will soak it up, mildew, and smell. Wood will eventually rot, but might let you see a leak as soon as it happens instead of after it's destroyed something.
Don
Auto Headliner
I am replacing the stuff on my H31 with auto headliner from a fabric outlet store. The stuff is incredibly cheap and looks real good. I have a light gray that looks better that what Hunter used. Both Sailrite and Boat US sell headliner materials but it's expensive. Good luck.
Rick Webb
Shag it Baby!
How about orange or purple shag carpet? The chicks would really dig it.
John K Kudera
Hull covering
Hi, You can buy fabrics similar to the original,or,carpet,wood, or maybe even pergo type flooring. Depends on your expertise. Countertops are recovered with formica type products,corian too! Best of luck!
