Just purchased a 1993 23.5 Hunter and have some questions that hopefully someone could help us with:
1) Can't seem to get the boat tight on to the trailer ... winched tight in the water ... moment we pull out of the water the boat backs off about 3" from the rubber stop ... backed in refloated the boat winched in again still the same problem ... backed in refloated and Chained the boat in case the belt is stretching still no luck.
2) appears to be hairline cracks diagonally forward from the front of the bottom slot where the keel is pivoting from ... these are about 6 to 10 inches in length ... should we be concerned about these or is this normal ... there is no water in the bilge ... it is dry as a bone and shows no signs of ever having water in it.
3) there is a 1/8 crack in the trailing edge of the rudder about 12" long ... thinking it should be filled in ... what product(s) should I use for this and is there any precautions I should take prior to sealing up the crack ie does the rudder need to be dried out before filling?
4) There is grey paint on the bottom of the boat that just wipes off with a rag ... the paint turns purple then the White Gell Coat is underneath ... not familiar with bottom paint but supprised it wipes off so easily ... this is a fresh water boat never been to the sea ... should I leave this and get it repainted this fall?
5) Is there a special carpet product that is being used on the trailer? The edges are starting to wear through so just wondering what to fix this with.
