New Hunter H23 owner intro and a couple of questions
7
Hunter H23 St Clair Shores, MI
Hello,
My name is Kevin and I live in S.E. Michigan.
Having owned 3 small sailboats over the last 40 years, I am not new to sailing, I am getting acquainted with the differences and tendencies of the H23.
A little history, I learned to sail on a 20 foot wood sloop that my father owned and sailed a lot through childhood on a small inland lake (the boat really was too large for that lake). When the wood sloop was sold, I purchased a Jetwind a little lateen rigged “super Sunfish” I sailed it for many years always wanting another sloop but the lake really wouldn’t support most of the sloops that I would run across. 20 years ago I bought an odd sailboat a Mcvay Moppet a small 13 foot sloop with twin keels. This got sailed quite a bit over the 15 years that I owned the boat. When the family cabin was sold, I sold the McVay since storage for the boat was impractical. $100 a month outside storage for a $300 boat and I had to take the mast and boom with me.
This summer my wife wondered if I missed the boat and felt that we should get another one. She never really liked the McVay due to lack of room, but it was the right size for the lake at the family cabin. Her wants led to a 22-25 foot sailboat search. We settled on a 1988 Hunter H23 and found a slip on lake St. Clair. I have repaired several items so far and we have sailed it a couple of times last summer.
I have a couple of questions after sailing it:
1. Unlike the old wood or Mcvay sailboat, coming through the wind from tack to tack the boat just doesn’t seem to come through the wind well. The method I have always used is to release the jib sheet, turn into the wind and as the bow crosses the wind tighten the opposite jib sheet. We never seem to make it through the no sail zone. Any suggestions?
2. The boat has had several non-essential parts removed. There are a couple of wood (teak?) boards to latch your feet into in the cockpit that are gone and the holes caulked. What are the dimensions for these boards?
3. My wife wants to know what is the best way to curtain the side windows, Vee berth entry and companion way hatches without drilling into the body of the boat.
4. We plan to do some travelling in the boat and she wants to be able to secure the cabin from the inside when we sleep aboard. Has anyone developed a work around for this issue?
Any suggestions are greatly appreciated
Thank you
Kevin
Jun 22, 2004
13
None None None
As far as tacking, I would suggest that you not release the working jibsheet until it as "back" winded and helps get the bow through the wind. As soon as the bow gains momentum through the wind, release the sheet while at the same time adjusting the new working jibsheet.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I tend to backwind my jib a bit during a tack, and also make sure you have some momentum. I just hauled my boat yesterday for the season, and have to winterize it - I will try to check the teak strip dimensions when I get back up there. It is not critical; they are about 2 inches by about 1/4 inch, and as long as the recesses, plus enough to reach past the screw holes. I would consider stainless bolts vs screws if you do replace them. Have not tried to solve your other issues.
Jun 9, 2008
1,857
- -- -Bayfield
Hunter response
The wooden pieces you are wondering about are about 2 inches wide and 3/8" thick. I have uploaded a photo for you to see how they fit.
As far as tacking is concerned, like the other guy said, back wind your jib a bit to help the bow come around, but also, before you go into your tack, get your boat speed up to help with that process. Don't point too much which will slow the boat. Fall off a little (just a little) to gain some speed and that momentum will help you get through the "no sail" area.
Regarding curtains, you can use velcro type products or there are some curtain tracks that have sticky backs that attach to fiberglass, but really drilling might be the best way with fasteners.
Securing the interior can be done with a couple of barrel bolts attached to the inside top companionway drop board at the edges, or even better yet at the top edge so that when it sticks up, the sliding companionway hatch cannot go back from the outside. If someone wants to get in to get at your wife, they ultimately will win, but this will give you enough time to get your spear gun out to shoot the perpetrator (just kidding). Do be careful on how you do this because I know some people who have locked themselves out of their own boat because of the brilliant ideas they employed to lock the boat from the inside.
1,279
Not that it matters much, but the wood strips on mine only extend a bit (say maybe one or 1.5 inches) past the recessed gaps. My boat does not have wood across the edge of the lazarette hatch, the gas tank recess hatch, or on the stbd side, all the way aft to the edge of the gas tank hatch. They are only long enough to provide handholds or footholds or places to hang lines (or whatever they are for) over the recesses. As you can see, they are screwed in at the ends and also the center.
Kermit
Jul 31, 2010
5,722
Welcome to H23 ownership! We bought ours 2 years ago and love it. Just the perfect size for us to sail and do a *little* entertaining.
Backwinding the jib is definitely the way to get the bow through the wind. I have no trouble tacking at all. Couldn't tack it at all when we took it out with the previous owner. Now I have no problems whatsoever. Keep at it. You'll get it right.
My First Mate really wanted some sort of window covering for ours. This is what we ended up with. http://www.zarcor.com/products/peek-a-booo/index.php They are a little more expensive than I wanted to pay, but she always wins. And you know what they say about Mama not being happy... They really are convenient and incredibly easy to install. And the best part is... First Mate is happy! We have not put up any other curtains. I'm pretty sure Zarcor would be happy to make blinds for the hatch but hold onto your wallet.
Looks like other folks have answered your other questions quite well.
Have fun and post pictures!
