new hunter 37c owner
HUDSON
Oct 22, 2017
5
hunter 37c pickering
Hello new friends
I just bought a 1984 37c fixer upper and not much info came with it .I am looking for a little direction on winterizing the plumbing . It has a hot water heater and I don't see a bypass valve per say and would rather not fill it up with antifreeze to do the hot water lines .
Would I drain tank and blow out line in and line out with compressor ?
Also cold water antifreeze in holding tanks and run threw cold water lines ?
I am new to bigger boats and any help would be great
Thanks
Sep 20, 2006
2,953
I disconnect the lines to the hot water tank and blow out the lines to the sinks. I have a drill pump ( Home Depot ) and connect to the drain on the HW tank and pump out all the water into a 5 gal. pail. A trick I came up with this year as I left my drill at home, I connected the drain hose fitting to my wash down pump and used it to pump out the tank. Worked great.
Jan 24, 2017
672
Hunter 34 Toms River Nj
Hello Hudson. And welcome
I have a 1983 h34 roughly the same vintage
By the way h37 is a great boat sailed that model a lot.
The most conventional method is to drain all the water tanks thru the hot water faucet untill all water is out. Don't forget to turn of the hot water breaker. After the tanks have run dry turn off the water pump. Ad approximately three to six gallons of consecrated none toxic antifreeze -50 degrees into the mane tanks. Turn on the water pump and let the antifreeze get pumped into the hot water tank and thru the hot water lines to the faucet, when you see antifreeze flow thru then that line is done. Note that for the first few seconds the antifreeze may be a bit diluted, let it flow untill you see the concentrate antifreeze come out. Repeat process with the shower and any other faucets. Now do the same with the cold side. Now the water system is winterized.
The winterize the sanitation system pump out the holding tank fill with fresh water and pump out Again. Flush the hold tank about three or four times to get it as clean as possible. After the holding tank has been pumped out then and two or thee gallon on -50 none toxic antifreeze thru the head. Before drying the bowl add about 1 oz. of vegetable oil to lubricant the internals of the pump.
Don't forget to do the engine.
You can also blow out all the tanks and heater using a leaf blower or shop vac but that requires you to disconnect all the water lines from the water pump after every thing has been drained thru the hot water faucets then disconnecting the in and out of the hot water heater
You then blow out all remaining water from the tanks to the pump.
Then from the pump supply lines to the faucets ant to the heater.
Blow out the heater Inline until the outlet line is dry.
Next blow out the hot water supply lines to all faucets.
This method is more labor intensive and if you don't get all of the water out of the system, you can cause damage to the tanks, heater, water lines. However if done properly with save your time in the spring flushing the none toxic antifreeze out of the water system.
If you are new and not sure what you are doing used the antifreeze conventional method it's easier and you are less likely to damage the water system.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I've never tried it on our boat, but with RVs blowing the lines out with compressed air and draining the hot water tank has always done it. I never had anything break from freezing after the lines were cleared. I did one time, loan out a 5th wheel to my brother and forgot to re-winterize it. that broke the hot water tank, many pipes, and fittings.
Ken
Sep 11, 2011
433
Hunter 41AC Bayfield WI, Lake Superior
Before you pickel you boat, please take a good drink of your food grade antifreeze. that is what you will taste for the next season if you follow Hunters recommendations. Antifreeze in your water system will suck as you will taste it until AUG. Blow out works great. Just did it to our 2004 41 for the the 9th time. No freeze damage ever. last winter on board temp gage said -6 to 104 F before launch.
First year we owned it we did the anti freeze in the water system. We would not cook with it nor drink it. it was only good to wash dishes or shower............unacceptable. I would never recommend filling your water system with food grade anti freeze ever as it is impossible to get the taste out. Sorry to be the contrarian.
Likes: Don Crowther
