C
crazy dave
The new Hunter 25 will be an exciting boat in many ways. First to update.Hunter Marine is a division of Luhrs Group. The new 25 is being built at one of the other factories and I have found their quality is pretty good and my hats off to them. It will be some time before we see a boat per day as Hunter wants this to be a good boat. The rudder was delayed as they saw a defect and that should be finished shortly. There is a temporary mast carrier but will be replaced.Starting with the later models, the head will have a door versus the privacy curtain.You can get the wheel steering option. You can add controls for gear and throttle for the engine on the wheel steering but Hunter is still considering this. However, this is what I would do. I would use the Tohatsu or Nissan (same engine) 9.8 four stroke long shaft fisherman style(tiller style) with electric start. I would purchase the SRC cable kit for the engine, controls from Lemar, modify the gaurd rail or buy one that Lemar will retrofit with, order two 3300 series cables and then install. You would have gear and throttle selection at the helm. I have always made my customers stop and start the engine at the engine from a safety stand point.As for the trailer, the jury is still out.
