Jerry
I've had this boat for about two months or so and haven't had it on the water yet -- my old boat was still at the slip. Unless I can figrue a way to mount runners on the keel, I'll have to keep it on the hard until the ice moves out. Looks like next spring -- so I'll continue to spruce it up.I have a question about the halyard winch. On the cabin top, one is mounted just aft of the main and jib halyard clutches (makes sense). Also, there is a winch pad (no winch) on the mast on the same side (starboard) as the main and jib halyards. What's its purpose? It's on the wrong side of the mast to be used for the spinnaker halyards.????Also, the Kenyon spars are not equipped with vang attachments. What's the best to install -- bails or solid mounted vang brackets?Thanks for the help. Come on spring!!!
