New Group 24 and Group 27 Batteries
Jan 18, 2013
30
Cape Dory 30 Solomons, MD
If I installed two new dual purpose batteries, a group 24 and a group 27, using the old style battery selector switch,(without an automatic charging relay) would there be problem as long as they are both lead acid types?
Nov 6, 2006
10,134
Probably fine.. but just as a precaution I wouldn't use "Both" unless the engine is running..
Feb 6, 1998
11,722
If these are separate banks then that is fine. If they are physically wired to each other in parallel not so good. Only parallel them with the BOTH setting when charging, but not discharging, and you'll be fine.
