New Genoa
E
Ed van Kessel
Can anybody give me some feedback on the purchase of a new Genoa. I am considering the North Sail NorLam with Luff tape and UV strip. Is it worth the extra money over a dacron sail. I am looking for a performance cruising sail. Also considering the UK Pentax Tape Drive, but really want a white sail to keep the traditional look. Any experience with the longevity of these sails would be appreciated. Ed
A
Allen
Another Option
I went with a Quick Silver bi-radial genoa from Doyle. Service was outstanding, the sail is white & that particualr cut of sail can be re-stitched if it gets stretched out as it ages. It might not be enough of a performance sail for you, but I thought I'd make the suggestion anyway. If durability is a factor, you might want to check 'em out: http://www.doylesails.com/sails-quicksilver2.htm Allen Schweitzer s/v Drambuie C-30 Hull # 632
Dave Healey
I represent Sails East and can provide you with an excellent performance cruising sail and would be happy to discuss this with you and provide pricing. I can be contacted at SailsEast_USA@attbi.com
Bob Horvath
Performance
I use North's NorLam and Gatorback, and UK's Pentax Tape Drive headsails. The UK Pentax Tape Drive is the best performance sail I have used to date.
M Meyer
Another Option -Seconded
I also replaced my original sail with a Doyle Quick Silver biradial cut genoa sail and have been very pleased with both the service and performance. I also strongly recommend the luff tape. The UV dacron protective strip on the sail leech was also a noticable improvment as far as performance over the Sunbrella leech on my original, although the Sunbrella looked better. Sunbrella is heavier and harder to get sail shape in very light winds. I also requested a nylon web strap and buckle on the leech line instead the usual nylon cord and clam cleat. It holds much better.
Tim S.
Another consideration
MILDEW! Laminate sails, especially roller furling sails are more prone to mildew formation than Dacron sails. Because laminate sails us a non-breathable Mylar film in their construction, any latent moisture rolled up can cause mildew. Mildew also feeds on the glues used in laminating. You can still get good perfomance with a Dacron sail depending on the fabric and cut of the sail. A radial cut Dacron sail aligns the fibers of the woven fabric better to the loads of the sail than a conventional Crosscut Sail. This means less stretch and better load carrying than the crosscut for the same weight Dacron. However, the higher the grade of Dacron the higher the cost. Nowadays it costs less to produce a polyester based Laminate fabric than a high tenacity woven polyester fabric. While A laminate will give you good performance at a good price, Dacron will give you greater longevity without the worries of mildew. Just don't go cheap on the Dacron if you want good performance.
