New dinghy for 2-hp honda
Apr 5, 2009
3,211
Anyone know of a small dink that can plane with a 2-hp Honda with one or two adults aboard?
My current dink is a 10'-6" Zodiac which was great when I cruised with my wife, teenaged daughter (and usually a friend) plus two Labradors. Anything smaller would have been unworkable. The daughter got married and moved away. The labs got old and moved on and will not be replaced so now it is just the two of us.
I have a good running 2-hp Honda and would prefer to not replace it. I have looked as several of the small inflatables and ribs that weigh about 1/2 the zodiac and have a 3.5 hp max rating.
Apr 5, 2009
3,211
Two of the boats I am looking at are the Highfield xxxKAM with air floor and the Highfield UL240 single floor rib.
My first inflatable had an air-matt floor and I loved it and hate the wood floor on my current boat. I saw a review of the KAM and like that it does not have any wooden components. The transom is aluminum and the seat and stretchers are molded plastic.
Jun 14, 2010
2,410
Nothing will plane with a 2hp motor. Probably a PortaBote would give the the best speed (they row well too) - the 10 or 12 foot models would plane with a 3.5 if lightly loaded.
Sep 22, 2018
1,869
Hunter 216 Kingston
I replaced our old Zodiac with a Hyfield CL290 - rib with aluminum floor more than double the weight of the UL 240 and kept our Merc 4hp 2 stroke with dolphin fin for power. It will “eventually” plane with about 300lbs of people and gear. I also use a Honda 2hp on our Hunter 216 so have some idea of it’s capability. It has remarkable power for a “little” motor and will move the sailboat along at 5knots at WOT.
My guess is you might get on a plane with one person moving their weight around to get it going but that’s not what your after.
I am very pleased with the quality of the Hyfield so you could start with the 2hp since you already have it and see what happens. The only way to know for sure if it’s acceptable is to try. :)
The 240 at 80 lbs and about $1700 sure puts a lot of check marks in the Pro category.
Jul 1, 2010
990
Catalina 350 Port Huron
We have an 8' portabote with a 2.5 hp lehr outboard. It would take a larger outboard to plane it, but it moves well with the 2.5. I can't really imagine needing anything larger even though it doesn't plane. Definitely faster than rowing it :)
May 25, 2012
4,338
well, actually, my 1988 merc 2hp, on my 10' quicksilver, inflatable floor dingy will plane quite nicely at about 14mph. BUT............................
so here's the way it's done, and it's quite easy: i lock up the steering by tightening the damper wing bolt. it is slightly offset to make the dingy go straight. then i set the throttle wide open and start my run. i then stand up with my feet wide on the floor. my feet and therefor my weight are well forward or the oarlocks and rowing seat there is no weight aft. the dingy easily goes faster. i steer like you would on a surfboard, leaning from side to side. i hold on to the towing bridle. it's fun as well. others in the harbor look at me like i am a moron.
unsafe? maybe? stupid? possibly? illegal? no?
my kids laugh at me and call me a dork
guilty as charged :cool:
i'm 6'5" and 230 ish
Aug 1, 2011
3,972
Out 8' won't plane with the Suzuki. Close, very close, but can't get over the hump.
Apr 5, 2009
3,211
I don’t see how 2hp with 2 adults and dog will plane anything but I will follow here.
Nick
Just to clarify, no dog and wondering if a 2-hp Honda will get any small light-weight dinghy to plane with 1 or 2 adults. I am talking about the 6'-8' range. Or current tender is 10.5' and is too big for our current needs. We will keep it for those times when we have visitors and need a bigger boat.
Aug 1, 2011
3,972
Here is the new 8' Aquamarine and the 2.5 Suzuki. It might be persuaded to plane, but as yet, has not, and indications are that with any kind of load it will not.
May 25, 2012
4,338
my personal testing is that with one person only, using an attached(duct tape or similar) 5' stick tiller. or the stand and lean method, an 8' dingy will plane if you are in front of rowing seat. with 2 persons aboard it will not. with 1 person aboard sitting aft it will not.
note: tests were done in fresh water, not saltwater. bottom of dingy was clean
Catalina 34 Casco Bay
I have a Honda 2hp outboard.. It is a very reliable engine.. Usually one pull. I've had it on a QUICKSILVER 9.9
and a West Marine 9. With me by myself it wouldn't plane and never will....
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I usually only run our Honda 2 at half throttle or less because it's way quieter. It won't plane wide open even with just me way forward in our 8 foot Livingston.
Likes: Hayden Watson
May 25, 2012
4,338
interesting results from different uses. in Wisconsin the premium gas is ethanol free. prop size, gearing, ..... i don't know
